07.14.2008, 06:22 PM
You do know that ALL switching BECs have the same issue -- if the output FET fails, it sends full voltage to the output.
It's inherent in the design of a step down (buck) dc-dc converter.
Patrick
That is true, but for some reason, the others have some circuit integrated into the IC to help prevent that (or at least reduce the chances). Usually, when they go, they just stop working.
Pdelcast
Pdelcast's Avatar
07.14.2008, 06:28 PM
Hmmm, not that I know of. I've seen many many UBECs die myself, and put full voltage out.
Any BEC that uses an external FET (pretty much anything over 2 amps) has the same possibility for full voltage output type failure as the Castle BEC.
Patrick del Castillo
President, Principle Engineer
