Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
07.15.2008, 04:19 PM
The 125 amp pack has plenty of power, so it should not overheat. As long as you set the cut-off the same on both ESCs they should both work just fine. I don't know what cells SMC uses, but theres a chance they're lower quality than flightpower, which has enerland cells. You can get 2 of these Trakpower packs , wire these in parallel and you will have packs with a hard case, 128 amps, and 6400mAh capacity for $30 more. It will only weigh 4 oz. more, which is still light.
The timmy - Revo 3.3 MM 9XL 4s , Rustler MM 4600 3s
The ferty - Dual velineon Revo 3s, Rustler velineon 3s
Blocker
07.15.2008, 04:27 PM
The TrackPower packs look pretty sweet too. Ill try this FlightPower pack out first since its readily available and you guys have helped me with any of my "unsureness" of the setup.
Should be running by this weekend.
