Darion
07.18.2008, 03:24 PM
Originally Posted by azjc View Post
for me it never has been, If I had to dischargea pack I will just run it the vehicle, and with the 0610i you can program how much capacity you want to charge
Thanks for the reply. This is what I am thinking also, just run it till it is at the cutoff point then charge to whatever the need is, use or storage.
Thanks again,
Darion
Duster_360
07.18.2008, 07:23 PM
The 0601i is super easy to charge to a %'age. After batt is setup, just enter what you want in TCS and start the charge. Will stop at the %'age you selected
I've updated my 0610i's firmware and like watching it work while connected to my laptop. I have yet to find any added discharge capability. Not sure that happened with the v1.5 firmware upgrade.
Still a super charger with the potential to get even better thru furure upgrades.
Darion
07.18.2008, 11:16 PM
Duster_360, Thanks for the reply. The discharge information was found in firmware update 1.6 listed here,
http://media.hyperion.hk/dn/eos/EOS-...-ManUpdate.pdf
The discharge information can be found under store mode in the PDF file and Hyperion to their credit isn't billing it as an all out discharge but a function to get the battery down to store mode if needed. They even give an example of how long it would take to discharge a fully charged 5000mAh to 60% of 7 hours at 300mA. Take a look if ya get a second and let me know what ya think.
Thanks again,
Darion
