sikeston34m
sikeston34m's Avatar
07.18.2008, 09:42 PM
Originally Posted by kevin23 View Post
1.17 firmware
50% brake and reverse
0% punch control and drag brake
high start power and high timing(15)
1.5sec arming time 12v cutoff
that is how it is currently setup
22/40 gearing
You did go to the Castlelink software and click on the Software tab, and then choose "Update Firmware"? This sends the updated firmware to the controller. Just making sure with this step. It's very important.
You might try some punch control, but the most important thing you can do at this point in the setup, is broaden your neutral band for the controller.
Throttle Dead Band - change to Large
What is the little Red box I'm seeing in your setup?
07.18.2008, 09:46 PM
Lojack for rc cars. Just in case it gets stolen...
It is a personal transponder for racing!
And make sure that you check your gear mesh. Make sure it is not too tight at one spot on the spur. Do you have the fan upgrade on the 2826?
kevin23
07.18.2008, 10:17 PM
[QUOTE=lincpimp;192743]Lojack for rc cars. Just in case it gets stolen...
QUOTE]
I do have the fan on the axi,I will change the throttle deadband.
Should I move the timing to the highest setting from high?
The gear mesh is good,I make sure to check it in multiple spots.I learned that lesson the hard way years ago
Thanks again for the help,
Kevin
