blueb8llz
07.20.2008, 03:17 AM
Originally Posted by hoovhartid View Post
yeah.
I guess my main point was to see if all 4 tires were giving the same about of torque under load. I suggest putting the truck up on something with the wheels suspended(free to spin). While the trigger is being pulled (lightly...if you are by yourself you can try to turn up your throttle on your transmitter till the wheels just start to spin)anyway--if one wheel is easier to stop than the other three, then that is the wheel that is spinning slower and causing you to veer off under throttle.
by the way..don't hold the wheels so tight that you break anything...i merely meant for you to find a part that may already be broken
just checked. all four giving same power. plus i just realized it cant be one tire not spinning as fast, cus if that was the case, it prolly would veer off to the same side everytime, but its actually random. and say if it was to veer off to the right, when i turn left on my remote and i mean just a little bit, instead of centering out like it should, now my truck would veer off to the left...sooo annoying! impossible to drive pretty much, but at low speeds it does not do this. and if it does veer off at low speeds i can just counter turn and itll center out.
brian- im pretty sure its at high speeds and not at the amount of throttle i apply. because if i applied a good amount of throttle from the start, my truck will wheelie and take off but itll still go fairly straight. i think its more of as the truck is going in higher speeds.
you maybe right about the toe in/camber but i had it running straight before. and i wasnt even accurate with my toe in/camber..i just eyed it.
but now, i made sure theres the same amount of thread showing on both sides so its pretty accurate.
and the front tires are even more toe in now so i thought that would help but nope. i mean i can try toeing them in like a crazy amount but the fact is, i didnt need toe in before so i know it doesnt need it. i mean worse comes to worse ill just toe in like 5 degrees haha. and still im not even sure if thatll fix my problem.
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
07.20.2008, 05:54 AM
That is how mine re-acted. It didn't correct itself if i counter-steered, it OVER-corrected itself. Even if I barely touched it.
...The difference is, Mine always steered to the right when I accellerated past 15-20 mph and when I countersteered to the left, it over compensated. It drove me nuts because I couldn't duplicate it at slow speeds to see what was happening.
Have you tried holding the truck up in the air and pulling the throttle to see if you have excessive wobble in the wheels. Or to see if one wheel balloons up more than the other? Or to see if the wheels turn?
Have you moved your steering while throttling the truck with the wheels in the air?
blueb8llz
07.20.2008, 07:55 AM
i have done this before. and now im traumatized lol. one day i flipped my truck and it was on its lid. so i decided to give it some gas just to see how much my tires ballooned. to my surprise, it ballooned a decent amount and i ductd tape my tires. i noticed that one tire ballooned alot more than the others and then....pop!! that tire got all unbalanced! unglued the tires to see that the foam had ripped in half. this all happened before my problems started.
since then, i replaced that one tire with new tires and foams.
so now when you tell me to do what i did awhile ago, im scared haha. i mean i can take it easy on the throtttle but i dont know when is too much, cus when i did it the first time, i wasnt even gassing too hard.
im really starting to think you guys are right, it miiiiight be the tires unbalanced. cus i just turned my truck over and i gassed it, all tires spinning good and balanced. but i didnt really gass too hard, the more i gassed it, my truck started shaking, but the tires were still straight. but this is no where as much throttle as i would give it if the truck was on the ground. so maybe if there was more throttle, i could maybe see some flaws with my tires...hmmmm.kinda worried to check that out. but we might got a good idea now...it could be the tires.
Duster_360
07.20.2008, 02:33 PM
Thats easy to test - if it is the tires, swap sides with them - put LF on the right front and the LF on the right. Same for the back. Now it should pull left. Simple to test, should take little time.
I don't think its tires, as badly out of balance as some of what I've run have been, I've never had one act this way. More possible is BrianG's suggestion that toe is off. Unless trx has changed, they come with 0deg toe on front and 1deg toe in on the rear. Caster is set with caster blocks or spacers, are they still there and in the same place on both sides? Camber is the angle the tire makes with the vertical viewed dead on. These would have to be pretty far out of whack to cause your prob, so it should be readily apparent.
Drive pins - there is enough tension on wheel axles to drive a wheel until you reach enough speed that a missing pin will prevent that wheel from staying in synch with the others - then it will veer off straight line. Pins are all or nothing. If one starts to back out while running, it usually hits bulkhead and you'll def know it. I have seem then fly out and not touch anything, pin's just all of a sudden gone. Again, an easy thing to check and eliminate as a possibility. Have you checked all wheel bearings? Another easy thing to check that could be causing this.
