MetalMan
MetalMan's Avatar
07.22.2008, 12:40 PM
A Y-harness is one way to go. It would actuate brakes the same way as if there were no Y-harness.
Another way to go is channel mixing, if your radio is good enough. For example, on my Nomadio React I have channel 2 for throttle and I set up channel 3 for the brake servo for my Savage and buggy. Moving the trigger will actuate either the brake or forward throttle, since I set up the brake so that it has no throw when forward throttle is inputted.
