bl-is-future
bl-is-future's Avatar
07.22.2008, 03:13 PM
well the charger is only capable of 10amps so i am not sure what could be happening. I use mine in link mode so it balances as it charges. bde has a good point. But since you said it worked fine before i imagine you are setting it up correctly.
this is what i do -
1. set up charger for battery
2. plug in battery to balancer
3. hold the mode button until the link light comes on
4. plug in the balancer to charger
5. hit start on the charger
I'm sure you are doing this but figured it could be useful if anyone else reads this
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
07.22.2008, 04:09 PM
I had this same problem with a LBA10 balancer. It turned out being wires shorting at the green plug on the side. I bought mine off eBay and the person from whom I got it wasn't very good at soldering.
ssspconcepts
ssspconcepts's Avatar
07.22.2008, 08:30 PM
this is what i do -
Yep...same steps I use...
ssspconcepts
07.22.2008, 08:34 PM
MRC has asked that I send it back to them with $40 to cover the repair costs and shipping. I guess this sounds reasonable...
In the interim, I will probably buy a second charger. I was thinking about the Hyperion EOS0610i Net. I hear it is a good unit...can anyone here confirm this?
