Need the best lipo....what brand?
speed demon
Need the best lipo....what brand? - 07.24.2008, 09:41 PM
I'm running a rustler and going for speed. I have hit 84.9mph by gps with a medusa 2200kv and a dymond 6S 4000mah and a modded MM.
I used my eagle tree and during my runs I pull 74-76 amps for about 3-4 seconds. My lipo drops volts to around 3.4vish per cell.
Looking to hit around 88-89mph. Was hoping a lighter(smaller) lipo with less voltage drop to get there. What do you guys suggest? Thanks
07.24.2008, 10:08 PM
The 25c flightpower lipos are about the best out there for voltage drop under load. Not sure if you will find a lighter lipo, but the 3700 fp lipo should fit your current demands...
jayjay283
jayjay283's Avatar
07.25.2008, 12:03 AM
this site will tell you the weight and other specs of most lipos available Link to the 6s page
azjc
07.25.2008, 03:14 AM
I agree with the post
bl-is-future
bl-is-future's Avatar
07.25.2008, 08:42 AM
yep i run the FP 25c as well.
david lamontagn
07.25.2008, 08:45 AM
I use the Thunder Power V2 extreme now (same quality than Flight Power), and it's a great li-po, and Pat, at rclipo.com is a great guys.
Free shipping and 10% discount at any time!
blueb8llz
07.25.2008, 06:40 PM
http://www.rclipos.com/PQ-5000RXQ-2S.htm
some new packs. looks pretty good decent price as well
blueb8llz
07.25.2008, 06:43 PM
for a $1 more, you can get these packs....they come wired with deans and hard casing as well. how come you chose the thunder's...are they better? and these packs are 30c cont. also
http://rclipos.com/PQ-5000RXQ-2S.htm
TexasSP
Something, anything, nothing
TexasSP's Avatar
07.25.2008, 06:55 PM
I would say any pack with enerland cells is supreme. I will say that my flightpowers are the finest lipos I have owned. The assembly, performance, and packaging is second to none. I also like the fact they come without a connector because I would just assume install my own.
www.cubicle101.com
speed demon
07.25.2008, 07:54 PM
I decided to build two packs. I ordered some elite 3300mah 30c cells today and will order some loose enerland cells if I can find them.
