Need 2-25 tooth 32 pitch, 6mm bore pinion
J3110
Need 2-25 tooth 32 pitch, 6mm bore pinion - 07.27.2008, 10:16 AM
Woops, meant to say 22-25 tooth...I have yet to see a 2 tooth pinion...what'd that be? a quadralateral?
Learning a lesson the hard way, it seems.
Long story made short, I got one of these guys only to find that it's got a 6mm shaft after the fact(didn't see the shaft dia mentioned in the testemonials and presumed it'd be 5mm).
So, I will be needing to find some 6mm bore pinions...or at least one of them.
I've googled and checked around at the various RC stores that I know of online and can't seem to find what I need, so I am thinking i may need to have one custom made?
This'll be going in my E-maxx presuming I can get some pinions for it.
Already been here: http://www.sdp-si.com/ (found it on runryder heli forum when googling 6mm bore pinion)
Couldn't find what I needed.
I also read somewhere that a mod 0.8 would be roughly equal to a 32 pitch.
Without a crash course in gear geometry can I get a quick yes or no considering my particular application?
J3110
07.27.2008, 10:39 AM
Eh, nevermind, I found what I was looking for on the traxxas forum: kershawdesigns makes 32pitch, 6mm bore pinions.
Guess that's hurdle numero uno...not the best start. :|
07.27.2008, 11:57 AM
Had no idea kershaw sells the 6mm bore pinions, good info!! Thanks!
bensf
07.27.2008, 12:10 PM
Does it have the standard 540 series mounting holes? I think one of the reviews said it was different ...
07.27.2008, 12:37 PM
Yep, it has m4 thread holes, and they are 30mm apart. A std 540 mount is m3 holes, and 25mm apart.
J3110
07.27.2008, 01:05 PM
Which would be hurdle number three unless I decide to mount it in the E-Revo...I guess they'll mount up using some combination of standard mounting holes in it's motor plate.
If that ends up not being the case, I can always modify the E-Maxx motor plate although I'd rather not.
This motor was originally going in the E-Revo anyways.
Really, it'll just need to last until I get my castle combo, but we all know there's no telling how long that'll be and weather or not it'll work right the first time.
Also, if the 7xl or MM in my E-Maxx goes out, I'll have a spare motor and ESC.
If everything keeps working like it should, the T-Maxx will be getting converted to brushless...finally...
07.27.2008, 01:14 PM
The front endbell screws on. I took one of mine off and drilled/tapped the std 25mm motor pattern on it. Not very difficult, you just need an 1/8 drill bit and a m3 tap. Put the holes 12.5mm from the center of the shaft, or 9.5mm from the side of the shaft.
The kb 45 motors are great. I have 4 of them and they make plenty of power and run cool too.
J3110
07.27.2008, 01:20 PM
Or I could: just get the right screws. ;)
brushlessboy16
brushlessboy16's Avatar
07.27.2008, 02:15 PM
hmm thats pretty neat, traxxas never ceases to amaze
