J3110
07.27.2008, 01:20 PM
Or I could: just get the right screws. ;)
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
07.27.2008, 01:33 PM
Could you not just put the motor in a vice (light pressure, with rubber or rag around it to protect it), hook up the ESC and battery and have it spin the shaft slowly (1/4 throttle or so) and use a file to grind it down a bit until you can get a 5mm pinion on easily? That would be how I would do it, except I don't have any 5mm pinions.
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
lutach
lutach's Avatar
07.27.2008, 01:49 PM
I'm not 100% sure, but I think 32 pitch is something like 0.8. Here are a few part numbers from https://sdp-si.com/eStore/:
32 Pitch:
S10A6Z-032H024 (24T, Hardened Alloy Steel, 0.25 face width). The bore D. is 0.2498 and some places show it as exactly 6mm, but others have it a tad bit larger (6.3). If it is larger, see if you can find some sort of brass tube that has walls that are 0.04 (roughly 1mm) thick.
0.8 Module:
A 1Y 2MY08020 (20T, 416 Stainless Steel, 6mm face width, no set screw)
A 1C 2MY08020 (20T, Carbon Steel, 6mm face width, no set screw)
A 1Y 2MY08024 (24T, 416 Stainless Steel, 6mm face width, no set screw)
A 1C 2MY08024 (24T, Carbon Steel, 6mm face width, no set screw)
A 1Y 2MY08025 (25T, 416 Stainless Steel, 6mm face width, no set screw)
A 1C 2MY08025 (25T, Carbon Steel, 6mm face width, no set screw)
Find a machine shop and have them put hole(s) for the set screws on the hub.
J3110
07.27.2008, 04:16 PM
Brijar!!!
That is a fantastic idea. I hadn't even considered using the motor as a lathe, itself.
I'd need some kind of measuring device or method that would ensure a true lathe, though. I guess trying to fit the pinion every so often might work...just work my way in toward the motor.
If anything, I expect to need a larger pinion. Depending on what my choices are, I am hoping I won't have to modify or fabricate anything...not that I am opposed, but wouldn't it be nice?
07.27.2008, 02:09 PM
Originally Posted by J3110 View Post
Now that is cool, I had no idea that traxxas would do that. I may have to pick up an ervo mount plate and that motor mount. Kb45 motors are great, and cheap too. A maxx or revo will never put much of a load on one. I run an 8l in a ofna gtp 1/8 onraod car, and it does not even get warm, even geared for 50mph...
