07.27.2008, 08:57 PM
Build two packs ++ -- i.e. p and then join the packs + - + - i.e. s
The end points are your + red and - black...
Good luck and just be careful charging / using / storing your pack for a while
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
07.27.2008, 09:11 PM
the stamping on the individual cells reads 3.7v 4700.....now is the 4700 the mah's?....if it is then how was the pack a 3s2p 8000mah pack?....if it had 6 3.7v cells at 4700mah's?.....and by the way Arkt1k....i connected the cells is this configuration:
Attachment 5138
now, my hyperion charger only charges up to 5000mah....and if this wiring is correct, then my charger settings should work if i set it up to charge a 2cell lipo at 5000mah.....right?
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
07.27.2008, 09:18 PM
Heres how the wiring has to go...
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
07.28.2008, 01:23 AM
thanks linc!!!...so just taking out one set of the puffed cells with turn my 3s2p 8000mah pack into a 2s2p 8000mah pack right?
Losi SCTE
MMP/1410 3800kv
Dx3s
tc3_racer_001
tc3_racer_001's Avatar
07.28.2008, 07:12 AM
yes, as long as you rewire correctly.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
07.28.2008, 09:15 AM
^^^^^+1
