Serum
Serum's Avatar
07.28.2008, 02:08 AM
Auw, that feels like a stab in the back Arthur. I always considered you where intelligent enough to see things in perspective.
Fact of a matter was that the 9920 and the 7XL preformed the same in my savage than the schulze/bigmaxx setup, so i jumped to that conclusion, considering the schulze setup was more than twice as expensive. my schulze burned, the bigmaxx his bearings where having play after a few runs. the 9920 didn't die on me, it was the entire setup i was impressed about. I guess i didn't know how to utilize the holy setup!
Maybe you can teach us how to utilize a 4 pole motor, and maybe this holy grale pays off.
07.28.2008, 02:24 AM
Catfight!!!
GriffinRU
07.28.2008, 10:25 AM
No, how I can do that to you, Rene.
The reason I mentioned your name is that any time we talking about plett's your posting with that comparison is always coming to play. And what is clear for you and couple other members here is not that obvious for the rest, while they do remember the BAD comments.
I bought couple used plett's and bearings were great, bearing failure can happen to any motor.
I use plett with MGM and Scultze ESC's, normal timing, geared for 25-30kRPM with 18 cell's NiMh or 5S LiPo. Plett has nice torque curve, but plett wasn't rated for high current and not for wide RPM range (it would spin up to 70000RPM, but temp would go as well).
Haven't use plett with CC controllers, no input here.
