07.29.2008, 04:29 AM
Not that this will help much, but I did find something interesting with my hyperion 5i chargers. They will attempt to repair packs that go below 3v per cell.
I over discharged an orion 3200 pack, down to 5.5v. The charger fired up and trickled out a low amp charge until the voltage came up and then charged normally.
I have also put single cells on these chargers that were under 2volts, and the charger has charged them up too. Same low amp start, until the voltage gets up a bit. Low amp charging takes a long time, sometimes days...
JThiessen
JThiessen's Avatar
07.29.2008, 03:10 PM
I think it was trying to do this. After about an hour on the charger, it would stop charging and gave a reading of "end flat check" or something like that.
