E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
08.03.2008, 05:41 PM
Check out my build in the truggy section, look for my user name. Using a Medusa 36-50-4800-5 motor and MaxAmps 6000mah packs. Very fast, drives straight, and stable. Uses 2.2 buggy rims, not sure if they normally come with 12mm hexes but they where on mine when I got it and for bashing I'm running a set of slash tires with I beleive a 15t pinion. Bore reducers and pinions are available from RC-Monster as are the Medusa motors. I would recomend getting the motor with 5mm shaft so no bore reducer is needed.
Bronco
08.04.2008, 07:56 AM
I've been searching for your built thread, but did not really find it. Did find other threads from you.
BTW, is 235$ a good deal for a brand new CRT (+52$ shipping to Belgium) ?
Do you know if there are any foam tires for this kind of car ?
