Just came back from running the Recoil. I changed the timing from normal to high and it still heats up pretty good. I'm going to try the smallest pinion I can fit in the car and see if temps go down. Motor wasn't as hot as it was with normal timing though.
Here is a data I got from running the Recoil at the track.
The MM still heats up even though max AMP spikes are in the high 50's. I even installed a 16T pinion in place of the 19T that was in the car before with the 60A controller. Patrick, what is the max RPM the MM can go with a 6 pole motor?
