Best option to go faster.... -
08.05.2008, 09:55 PM
Should I try a new motor, or stick with my current motor and go with a higher cell count battery.
I currently run a Neu 1512 2.5d, I went with this motor to get good run times... and I do, probably over 30 minutes... I bought 3 batteries thinking I would need them ,and only use 1. Runtimes are not an issue.
I would like to go faster. Different motor? or 6 cells?
Yip Yip Yip...
08.05.2008, 10:33 PM
How hot are the motor/esc/batteries getting? You could always gear up.
08.06.2008, 02:37 PM
30mins on a 1512 2.5D? You could gear up for sure. Here's my setup:
-SH buggy, with 38/11 diffs
-same motor as you, finned can
-geared 18/44
-4s 4800mah 20C Lipo
-about 45mph top speed and ~15mins runtime
08.06.2008, 09:56 PM
On a real hot day it tested at 118 for the motor and esc, and about 110 for the battery.
I was thinking it felt a bit weak in the midrange,.. Like a large grass jump its not pulling, its slowing down. So I think gearing up would make that worse.
I think my gearing is 17 pinion, 54 spur. STD revo tranny locked in second.
Flightpower 30C, 4500mah
Center diff.
i know my top speed is no where near 45, I would guess 25...
08.07.2008, 12:47 AM
Yeah, definitely gear up. That motor is much more capable... My motor typically comes off at about 160 deg. depending where I'm driving.
08.07.2008, 02:40 AM
this is in the Revo forum....is it safe to assume its a Revo...could you supply more info about your setup?
08.07.2008, 05:51 PM
Just Revo 2.5 conversion,
locked into 2nd, Std transmission gears.
Revo center diff.
Motor brake
Single steering servo
Quark 125b
Neu 1512 2.5d
17/54 gearing
Flightpower 4500, 30c
That should be the basics.
I will order a larger 19 tooth pinion. Should I pickup one more? If so what size?
Thanks.
08.07.2008, 06:43 PM
Revo center diff.
Motor brake
Quark 125b
Neu 1512 2.5d
17/54 gearing
Thanks.
since the biggest spur for a Revo is a 40 tooth ..are you using a different brands spur?...and the 1512 might have more problems gearing up not as much torque as the 1515...and what voltage battery are you running?
08.07.2008, 06:59 PM
probably running a jato or emaxx spur
08.07.2008, 08:01 PM
Its an Associated Nitro TC3 spur.
the voltage is 14v.
Like previously mentioned it does seem a bit weak when there is more load than just a flat dirt surface.
08.07.2008, 09:02 PM
if it already feels weak, and if its in your budget, try to get a motor with more torque this will enable you to gear up for more speed, the Revo is a bit on the heavy side..I feel the 1512 series is more suited for buggies
08.08.2008, 01:56 AM
BL motors can sometimes feel "flat" when there isn't enough of a load placed on them. Ever heard someone use the expression "it woke up" when referring to a BL motor and increasing the pinion gear size? Well if not, it's happened.
08.08.2008, 08:30 AM
Well I will try the pinion 19 sound good? Any others?
The motor upgrade I will wait, I have some winter plans for this things, a new motor can be an option.
08.09.2008, 01:11 AM
It can't hurt. Just watch the temps.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
