azjc
08.07.2008, 02:40 AM
this is in the Revo forum....is it safe to assume its a Revo...could you supply more info about your setup?
Trick440
08.07.2008, 05:51 PM
Just Revo 2.5 conversion,
locked into 2nd, Std transmission gears.
Revo center diff.
Motor brake
Single steering servo
Quark 125b
Neu 1512 2.5d
17/54 gearing
Flightpower 4500, 30c
That should be the basics.
I will order a larger 19 tooth pinion. Should I pickup one more? If so what size?
Thanks.
azjc
08.07.2008, 06:43 PM
Revo center diff.
Motor brake
Quark 125b
Neu 1512 2.5d
17/54 gearing
Thanks.
since the biggest spur for a Revo is a 40 tooth ..are you using a different brands spur?...and the 1512 might have more problems gearing up not as much torque as the 1515...and what voltage battery are you running?
