bustitup
08.08.2008, 10:36 AM
Originally Posted by skellyo View Post
If your packing slip/invoice shows a 1515/2.5D I don't see a problem. If it says 1512/2.5D, I'd definitely call them.
well thats another thing..I wasnt given any paper work what so ever....just a motor bubble wrapped in a small box
but I am going to call them today again to ease everyones mind
08.08.2008, 10:41 AM
Looks to me like the girl on the phone read the numbers wrong, so she had the same motor in her hand. I am sure that the price was marked on it, so she just relayed that over the phone. So the mistake was hers, and probably had nothing to do with the price. The fact you can still use it for you application is great. The cost difference between a 1512 and a 1515 new are no that much. I do not see this as stealing. The motor may have been a test motor, or a repaired motor that had very little use and a caring first owner.
I recently bought a neu from a forum member for $100 bucks. It had a loose shaft, and he offered it to me for that price. I shipped it back to neu and they fixed it for me free of charge and returned it to me. So I also have a 1515 for $100 and do not feel like I stole it...
If Neu accidentall refunded your money for the motor, I would call them about that, otherwise I would enjoy the motor!
coolrunnings
08.08.2008, 11:24 AM
The motor is not brand new it is used.
bustitup
08.08.2008, 11:55 AM
OK..everyone can relax and rest assured that there isn't a thief in the forums...j/k
I just got off the phone with the man at neutronics (Steve) and explained what happened....he was def surprised but whenI said I called because I didn't want to cheat anyone he said not a problem.....if I was satisfied he was OK with it and I didn't owe them a dime
bl-is-future
bl-is-future's Avatar
08.08.2008, 12:08 PM
now good things will happen to you. seriously though, see all is well.
rootar
rootar's Avatar
08.08.2008, 12:28 PM
Originally Posted by bustitup View Post
sir you are correct..these motors are sold on a Neu site and all the motors sell for about the same price weather they are 1515 or 1512......they are motors that have been used for testing or returned for some reason.......nobody got screwed...they also come with full factory warrantee also
btw what are using the motor in rootar?
i knew exactly what had happened, i had called about 3 weeks ago asking if they had any testers or rebuilt ones forsale, but they didnt have any at the time so i shelled out and bought mine from mike, but mine is the new updated version, with bigger bearings, flatspot on shaft, and thicker screwed on endbell, (basically a teckno version but black with holes in the ends.)
im using mine in an Xray 8xb on a 5s 5000 flightpower pack
if i was you id keep it these are awesome 5s and 6s motor from what i understand, but on 4s they arent quite as "explosive"
bustitup
08.08.2008, 12:43 PM
Thanks for the confidence Rootar......I also knew I was ok but do feel better since i called
anyway the 1515/2.5 has a 80 amp rating ....you guys think these batts would suffice?
NEW TrueRC 5000mAh 11.1V 3S1P 15C Pack
HIGH PERFORMANCE PACK FOR AIRPLANE OR CAR
Balance plug, works with all of our balancers. Can be modified for AF Blinky for use without adapter.
Size
28mm x 45mm x 160mm
Weight
395g / 13.9oz 12AWG WIRES
Discharge
Up to 75A Continuous
100A Max burst
Price
$89
Fits PERFECT into Traxxas E-REVO
with the L shaped bracket removed.
L shaped bracket is for holding down shorter packs and can be easily removed since this battery fully utilizes the battery bay. For best fit, install the battery into the bay with the wires first.
PERFECT FOR MMM or NEU motor setup and any other 6S capable ESC and Motor
bl-is-future
08.08.2008, 12:47 PM
i feel the only thing lacking is voltage. 3s is a little low for a revo. 4s min i woudl say. But if you are saying 2 of those above than YES they will be fine. I just got a set of 2s (4s total) true rc and run them with a 15151y in a hyper 7 and they dont even get hot, barely warm and NO PUFFING. great lipos for the money.
bustitup
08.08.2008, 12:50 PM
yes I meant 2 of them for 6's...they only had 75a cont. so I didnt know if they would be ok
I have the same 2s2p 8000 15c two of them for 4's in my medusa 36-60-2000 and they are great
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.08.2008, 01:03 PM
Give the guy a chance. He is obviously not dishonest as he came on here honestly seeking advice. I am sure he will make an effort with neu and all will be well.
www.cubicle101.com
bl-is-future
08.08.2008, 01:04 PM
sorry tex you are a little behind... he has contacted neu already and all is well
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.08.2008, 01:16 PM
i dont think cost is really the point. It is a point of honesty. If you are dishonest it WILL come back to bite you in the ass sooner or later. I have seen it happen to many before.
Damn right.. it always comes back and bite you in the ass...
but I bet you Neu will just let you have it without any extra charges... Hopefully this is the case...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Byte
08.08.2008, 01:44 PM
What do you mean with this? Do they sell motors that were not 100% perfect? And you can get them cheaper than normally?
Sorry my Englisch sucks like hell
ah-see
08.08.2008, 02:00 PM
Here take a look at this page:
http://www.neumotors.com/20061222/Special_Deals%21.html
Byte
08.08.2008, 02:04 PM
Originally Posted by ah-see View Post
Whoot! Thats awesome! Ty!
Just 1 question, they don't update that page often, right? Or why do you guys call them?
