tc3_racer_001
tc3_racer_001's Avatar
08.09.2008, 06:42 AM
well, thats where the mamba max pro comes in... complete with sensor port...
the reason why?? simple (in my eyes anyway, im no expert, if it works it works if it doesnt, try something else attitude) is ALMOST ALWAYS better. with sensored, u need a bit more stuff in the motor (sensors etc) and u have an extra wire to deal with. if you can get the same performance without these, WHY NOT???
sensorless were first made for planes and smoothness on startup (where sensored is sometimes better) isnt an issue at all... and there were no manufactures making sensorless/sensored motors for electric cars... so people naturally used the only thing available, for the better or worse :) since then sensored has (for some dumb reason) beed accepted as the racing standard... perhaps sensorless was too good :P
anyway, we are just using motors designed for planes and controllers (originally) with modified brakes and essentially the same hardware.
now there has been a revolution and many choices are available, but so far the efficiency and the KISS method are top priority, i dont care if its the slightest bit rough on startup and at crawling speeds, when will you be doing that on a racetrack!
ryan
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Five-oh-joe
08.09.2008, 01:53 PM
The issue isn't whether the motor is sensored or sensorless in terms of power output. Aveox made some very powerful sensored motors when they were still in the RC game.
The problem is that motors like the HV4.5 and HV6.5 appear to be based loosely on their little brothers (ROAR legal motors, which have design constraints). These ROAR designs seem to be pretty power limiting (I don't know if that's because of the iron stator, wind type, or rotor size, or perhaps a combination of these three or even more variables; their tiny rotors don't exactly help with torque output though).
The best option I've seen so far is hybrid systems in terms of sensored vs. sensorless. I believe the Mamba Max Pro will be doing something like this, and ESCs like the Speed Passion GT ESC also use this. This way, you get the best of both worlds (low speed driveability and cog free operation, coupled with variable timing once the motor gets going that is associated with sensorless systems).
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.10.2008, 03:12 PM
I would think a purely sensored controller would be simpler than a sensorless controller... mainly because you wouldn't need all the "sensorless" sensors (IC's, etc). I honestly wouldn't mind having a sensored Neu over a sensorless version... heck, it would be ZERO cog, run with less issues, and maybe even more efficient?
