08.10.2008, 09:55 PM
I burned out a few dremel brand tools, and ended up with some sort of cheapo one that has a flex shaft. It has a variable speed and works fine.
I also use a dewalt jigsaw and metal blades to cut al. Works better than anything else I have tried, including the band saw.
Had to use the dremel knock-off today to clearance the bottom of my v1 MMM. Did the job fine.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
08.10.2008, 11:56 PM
Hmm, that's weird, I have had my 400 series XPR for several years now and it's been perfectly fine electrically and mechanically. I usually use the flex shaft, and sometimes use the blade sharpening attachment (which really just guides the grinding wheel). It has been quite useful, though I probably only use it once a week to once a month, as I don't have much that needs dremeling.
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
Duster_360
08.11.2008, 07:44 AM
Yep, my 395 will get hot under continuous use - I keep a pr of mechanics gloves around - started doing that for soldering where the wire I was holding would get hot before the solder set. Use them and I'm aware dremel is warm, but not much more. Used to be I'd do like BrianG and just take a half hr break when it got really warm.
Haven't have to clean the switch - if I just run the switch back and forth with it off/unplugged a few times every so often that seems to keeps it clean. Been happy with it for more than 3 yrs and wouldn't want to be without.
