hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
08.11.2008, 05:58 AM
Originally Posted by tc3_racer_001 View Post
whats this about pulling the red wire to program?
to run a castle bec, you remove the red wire from the esc;
do you mean if you ran without the inbuilt bec he would have to replace it to program and then remove it again to run it?
yes, not a dumb question.
there is a simple solution tho. You buy one of these (servo extension wire) to run between the esc and the Rx;
cut the red wire on the servo extension.
when you need to reprogram, just unplug the esc from the extension, do whatcha gotta do, and put it back.
i too like to know everything - or as much as i physically can -
me too!
hope that helps...
