jhautz
jhautz's Avatar
08.12.2008, 01:29 AM
Run it and have fun, your temps are fine. Running on soft sand adds a pretty heavy load to the system. Everything in it will run a bit hotter than on the street.
to make it...
or break it...
Silent...But Deadly
david lamontagn
08.12.2008, 03:25 PM
OK thank you all, i think that i'll keep my actual gearing (24/62, i run the V2 hybrid buggy ratio), because i have try the 22T pinion, and my truck seam to have a realy noticable drop in power
Maybe it is because the motor have less load on it , do you think that,s a reason why it seam to not pull as hard as when i have the 24T pinion
