coolrunnings
08.12.2008, 06:19 PM
A buddy of mine has an lst and wants to go brushless and I'm tying to advise him but dont know where to begin. Maybe he could get a muggy chassis plate for his truck do you guy's think it will bolt right up?
bdebde
That's All Folks!
bdebde's Avatar
08.12.2008, 08:45 PM
The front and rear assemblies would bolt up, but you would still need the center diff. A couple other things are different too. The shocks and shock towers on the muggy are shorter. The diffs are different ratio (muggy 4.09, lst 3.3) which could cause a pain with gearing if switching to center diff with lst diffs F - R. In fact I have a LST2 i am working on with a muggy center diff and I am using the muggy F and R diffs.
lind5
08.14.2008, 04:05 AM
there is quite a bit thats diffrent with the muggy i looked at mine last night i would have thought that it would be easier to to just get a motor mount and mikes pinion addapter
or even just build a new top chassis plate it was easier than i thought it would be but i do own a scroll saw a bench sander and a drill press
keep us posted mate.................
