tc3_racer_001
tc3_racer_001's Avatar
08.16.2008, 07:29 PM
i think the reason why, is becuase the mmm CAN draw heaps of current to start off... the ability to do this makes it so smooth (i think, never actaully run one yet...) it then passes this huge current to the motor making everything that little bit hotter. also, would the drag brake cause lots of heat? it would be great if you could change 1 variable each time and drive the same and see if you can get the temps to match the MGM?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
08.16.2008, 07:37 PM
That is probably why the batt temp is so high. If I fiddled with it long enough I could probably the temps similar. All in all, I believe the MGM set up would run cooler in the end.
MetalMan
MetalMan's Avatar
08.17.2008, 06:46 PM
Was the drag brake on the MGM set? If not, that could explain excessive heat in the MMM and 9XL.
Originally Posted by gramey
What's the current rating of the MMM?, I know the MM V2 is rated at 200A continuous so presumably has a higher burst rate than the MGM 160. The MGM is obviously rated at 160A's continuous and 200A burst, so the MMM if rated the same as an MM V2 would feel more powerful because it is.
This is the reason why CC doesn't rate their car ESCs for current anymore. There's no standard for the ratings.
08.17.2008, 08:37 PM
There was a drag brake on both controllers...don't remember the setting of the MGM, the MMM was at 30% I believe.
To lower heat on the motor I will reduce timing to 0, remove drag brake. Do you think that I can lower batt. temps. using the mmm?
