Pdelcast
Pdelcast's Avatar
08.18.2008, 05:38 PM
It only runs during a cold start -- which requires that you have power removed for a few minutes.
The fan controller is designed to run the fan if it fails... so if the controller dies, the fan should run all the time.
Patrick
Patrick del Castillo
President, Principle Engineer
RBMike
RBMike's Avatar
08.18.2008, 05:40 PM
Patrick
Patrick, I think after replacing the fan at home last night, that should qualify as a cold start correct?
Pdelcast
Pdelcast's Avatar
08.18.2008, 05:46 PM
Should be. I'd check the connector though -- make sure that it is attached correctly. Like I said, the fan controller is designed to make the fan run all the time if it fails.
Patrick
RBMike
RBMike's Avatar
08.19.2008, 12:08 PM
Patrick
Patrick the fan connector is solder well & solidly attached the the CCA. The fan will run when removed & powered by a 5V supply. The connector Ohmed out to the board OK on the +V side but on the ground side I had a little trouble getting contact inside the connector. I found alot of conformal coating inside the connector which I cleaned out & then had no trouble ohming that connection to the CCA's ground. I tested the whole unit wired in the car again and the fan will not come on.
Mike
Update: Talked to Thomas at CC & he said he would send me out a new one with a mailer to return the bad one. Again, great customer service at CC.
