Kyosho spur for the Losi diff
speedracer1129
Kyosho spur for the Losi diff - 08.18.2008, 08:19 PM
Hey guys. I just picked up my next speed project, a Losi 8ight T. I need to know what do I need to mount a Kyosho plastic spur gear on the diff? Any help is appreciated!!
diff
ilpufxit
ilpufxit's Avatar
diff - 08.18.2008, 09:00 PM
The Kyosho gear will bolt right onto the diff no problem. I did run into an issue with clearance to the RCM mount, the Kyosho gear is more offset and it binds on the mount. I probably could make it work but I had a different conversion mount that works fine.
rchippie
rchippie's Avatar
08.18.2008, 09:09 PM
Mike said his LOSI motor mount was not made to work with the kyosho plastic spur.
REAL MEN RUN BRUSHLESS
speedracer1129
08.18.2008, 09:13 PM
I hope that is not the case as I am happy with the Kyosho mount I got from him!! Maybe he can chime in and give some advise as I have to use the Kyosho gear for my application!!
rchippie
rchippie's Avatar
08.18.2008, 09:20 PM
I was talking about his LOSI motor mount & the kyosho spur, not the KYOSHO motor mount . This is what he told me when we talked about it a while back.
speedracer1129
08.18.2008, 09:31 PM
I know. I was referring to another car with his product.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.18.2008, 10:37 PM
No mods to the RCM mount necessary. Here is what you have to do: Find a thin 8mm washer that fits on the front side of the center diff rear bearing and you are set. The main problem that I encountered with the kyosho spur was oil leakage. The slot where the o-ring sits is a little wider, which may to blame.
Area 52 Ranch Raceway
T.R.C.R.
speedracer1129
08.19.2008, 11:57 PM
Thanks for the info!!
tc3_racer_001
tc3_racer_001's Avatar
08.20.2008, 06:50 AM
my hyper diff also leaks slowly.
o well. a small price to pay for that extra surface area and quiet
should be less hard on the pinion too.
hope you get it working
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
