Sammus
Sammus's Avatar
08.19.2008, 01:32 AM
Originally Posted by TDC57 View Post
I also swapped out the front sway bar for a lighter 808 bar
Have you read any of my posts at all? if you want to reduce oversteer, you want a FIRMER front sway bar and/or springs, and SOFTER rear springs/sway.
That said, with an unlocked diff and proper tyres, you may not even have an oversteer problem anymore. But putting a lighter front bar on certainly wasn't part of the solution :)
messed with the toe in / out
Could you adjust the rear? it looks like its got some nice toe in on the rear in one of the pics (could just be the angle), but the rustler comes with 0deg toe on the rear, and there is no way to adjust it without flm tranny or mods.
