08.20.2008, 05:08 PM
It's got the spool. Does that mean I have a 51t spur? Do I have to change anything about my plan?
08.20.2008, 05:35 PM
I would not run the c50 maxx over 4s if I were you...
Mine ran nicely in a hyper7 on 4s. Had it geared 11/46 and it ran cool, and did around 40mph.
08.20.2008, 08:24 PM
Arkt1k: SDP-SI is where I got mine. Sort them for M1, Acetal w/Brass insert, Hub w/SS, 8mm bore size.
BL_RV0: Are you gonna run foams? The stock tires will balloon a little bit. I noticed it was set to 0 in the calc. The GTP kits are very nice. BrianG, B4Maz, and myself are also working on conversions. Good luck with yours!
Not going to run foams. Forgot about the ballooning, but I figure it won't make much of a difference.
I have one to and will post up - yes it is 51...
I ran at the w/e with a Hacker B50 7XL 4s geared 22/51 and it was recorded consistently at 48mph/50mph on the radar...
How well does that spur hold up?
I should be asking you, did you have any problems?
Sadly, I don't have the funds for a 4s pack, and couldn't bear to sell the Hacker, so that's why I chose an onroad. Takedown ran the Hacker in a Matrix truggy on 5s and he said it did fine- in a TRUGGY!
I'm sure it'll do alright in the onroad.
08.20.2008, 08:47 PM
Ordered from Mike:
Ultra GTP Mount
Bore reducer
16t pinion
08.26.2008, 09:39 PM
Got the GTP, and the stuff came from Mike!
Got all the nitro stuff removed, installed the RCM mount and pinion, along with the C50-Maxx.
Pics:
