MetalMan
MetalMan's Avatar
08.21.2008, 01:53 AM
The 22t should give approximately the same top speed. Which motors are you comparing? That will make a difference. For example, the VXL 3500 uses a larger rotor than the Castle motors, and so runtime is affected accordingly.
Jason
08.21.2008, 01:56 AM
for now I use this one :
http://cgi.ebay.com/4300KV-9T-Brushl...QQcmdZViewItem
MAX AMPS FOR THIS MOTOR IS : 40AMPS
do larger rotor give more or less runtime ?
