tom255
tom255's Avatar
08.23.2008, 03:13 AM
On buggy if you flip center diff it will not fit under body. Two - three solutions to fit bigger motor, redesign rear torque bar or use bigger spur gear, place some spacers under diff or make new whole diff mount what is taller.
I designed mount for 60mm medusa motor its more than enough on buggy, no reason to use any bigger motor on that.
I will put 74mm motor to get gearing limits...
