08.23.2008, 05:08 PM
Worst case scenario is that they will be overworked and puff after use. If they are a REALLY good price, it may be worth the risk. If you do, I would start with the lowest gearing watching battery temps and gear up slowly.
edep345
08.23.2008, 05:12 PM
those numbers that I posted, 96amps continuous, and 120a-136a burst are these good numbers, or are they on the weak side? What's making you "hesitant" with these batteries? If those are good numbers, then, wouldnt this turn out alright? or is it the brand?
08.23.2008, 05:52 PM
I use them exact lipos...
What I can say is, for about $30-35, they work suprisingly well. Temps at the end of a run using my last setup before the motor melted (9XL 62/24 4s2p Gmaxx) were about 120*f or so, and they were hitting 3.0v per cell after about 10-15minutes of moderate bashing and speed runs on grass. They actually were only about 2/3rds discharged going by the mah I put back in, but they dont seem to hold their voltage so well under a reasonably large load.
I would say as an introduction to lipos and figuring out what kinda performance/speed/gearing you want to use, they work well enough, and in a lighter truck they would do even better, but for a heavy MT... you get what you pay for.
There are some very similar lipos on ebay right now rated for 5000mah 12c- I suspect they would be a bit better, and same kinda price range, but zippies arent much more, so its personal choice really.
edep345
08.24.2008, 12:42 AM
what exact power e.c. packs are you using?
