edep345
08.24.2008, 04:48 PM
Gear for about 30-35mph. That will lessen the load on the lipos.
Do you plan to still use the 2 speed and mech brakes? That will take some load off the motor and thus less load on the lipos.
96 amps cont wilth a 4s setup is ok, just do not try to gear the truck up to 40+mph. Converted savages are not the lightest truck. I run my savage with the 2 speed and mech brakes. I use a 14xl and 8s lipo. My packs are 3600 12c packs, older polyrc cells.
actually, the 3spd, but if I DO plan to use these crap lipos, I guess I will need to convert back to 2spd, and yes mech brakes, 9xl motor. So you seem to be doing fine, is that because of the HUGE voltage? So basically I will have to run my flm ext sav x ss at 35-40 /w 2spd, mech brakes to ensure good performance with these lipos?
