gimpygolden
gimpygolden's Avatar
08.24.2008, 05:28 PM
I've had my share of shelf queens!
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
thanks for the info
plettenbergs
plettenbergs's Avatar
thanks for the info - 08.24.2008, 05:55 PM
i have run the truck about 6-7 times in my giant sodded yard with dual Bigmaxximums installed on 24 cells nickel metal....broke two input shafts and sheared off two output shafts(all have been upgraded to hardened steel)....ran great between break downs...the last time i ran it the sealed bearing for the input shaft disentegrated...since then i sold all my batts and chargers and will be getting lipo batts to decrease poundage!...that should help the drive train!!!!my ULTRAMAXXED trani gears are holding up beautifully!.....i will try the 101001....i am going with two flighpower 5s batts,is this too much for the Schulze esc?
