08.24.2008, 06:33 PM
When you say one battery, do you mean a single 4s lipo?
Without using the built-in bec, you will have to use an rx pack or UBEC- leave the esc turned off when you plug in the batts, and that will take the load off of the built in bec.
pretend there is only a single BL motor, ignore the lvc if you have one of the newer hvmaxxes.
