Takedown
WARNING: May become violent.
Takedown's Avatar
08.26.2008, 11:31 PM
If one of the rear wheel nuts is loose then it's not in fine condition is it .
Hard to see that from the naked eye.
RIP- Tammy (9/14/08)
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.26.2008, 11:42 PM
I know. A good check that I do on my bikes every now and then is to just grab things and flex them. It's a good way to look for cracks in the frame or loose bolts. You are right though and you are never going to see everything. I had a bottom bracket seize up on me once no warning at all.
bensf
08.27.2008, 12:28 AM
A good check is to pick up the bike and drop it. If anything sounds/feels loose check it out. Also if its creaking it probably means something is gonna break/fall off/stop working. Like my crank arm that I was to busy to fix.
