08.31.2008, 08:28 PM
It depends what you define as a short. To me, a short it touching the + and - terminals together with a solid connection. And no, that's not good. However, when something happens to an ESC that "shorts" the leads, there are a number of resistances to consider; connectors, length of wires, PCB traces, FET internals, etc, which all limit current to some degree. So, it really is not a direct short. And when something does go wrong with the ESC where something burns up, the connection causing the short opens quickly so the short is no longer there anymore. ESC fireworks can seem to be really bad, but they are not designed to dissipate anything over ~30W. When an ESC shorts a battery, it is forced to dissipate over 1000W.
Besides, our setups can pull well over 200A+ of instantaneous currents for a very brief moment. That is pretty darn close to a "short circuit" in my book if you want to get technical.
Dragonfueled
Nore more bump boxes and after run oil
08.31.2008, 09:40 PM
Well I could can shed some light on this subject lol . My v2 when up in flames a couple days ago and i was using the True rc 8000 15c lipos. One lipo died a horrible death and one survived. When I opened the pack out of curiosity the tabs on the lipos had obviously been seriously heated and you could see burn marks. The pack had no voltage. Somewhere in the connection of the cells went bad and opened. I tried jumping the tabs also to isolate the wireing and no good..... So yes a shorted esc can kill a lipo. Im so scared it will kill my enerlands next but i figure they can take the heat better then the true rc's
Brushless ..... I put that s... In everything.
