Wet Lipo's
gimpygolden
gimpygolden's Avatar
Wet Lipo's - 09.01.2008, 04:18 PM
I'm looking at buying a boat
http://www.proboatmodels.com/Product...ProdID=PRB3750
and plan to run Lipo's.
What I'm worried about is the batts getting wet.
I have read somewhere that too neutralize a Lithium battery before disposal you submerge it in water and it will no longer hold voltage.
From what Ive been reading alot of boat guys do run Lipo's, I'm just concerned because it is likely that some water will find it's way into the hull.
Has anyone ever got there Lipo's wet out bashing, or any advice from any boaters.
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
azjc
09.01.2008, 07:18 PM
eversinced you posted earlier in the weekend about wanting to buy a boat I too have been interested and have spent a lot of time doing some research and I have found that no matter how good a boats latch system is it is a good idea to tape the cowl area. I have since joined a few boat forums and that has been helpful let me know if you need a few links
gimpygolden
09.01.2008, 07:30 PM
I've also joined at Offshoreelectrics and been reading up at RCU and RCGroups.
So your thinking of going with the SV27?
I still really like the Formula Fastech, I'll check one out at the LHS on Thursday
azjc
09.01.2008, 07:37 PM
yeah...the SV27 is the one to get you can get one for under $300 and dont need to do much to make it scream.... they seem to be the TMaxx of the boat world....Like Linc says keep it stock except for the prop and use a 4s lipo....I have seen some videos and they have been impressive, I also have seen the bigger gas boats I do like them but a good one will run at last $1200
also I joined www.rumrunnerracing.com
gimpygolden
09.01.2008, 08:55 PM
30 Mph is enough for me, I just want to tool around in my Inlaw's pond. I plan on running 2x 2s 6500mah as I can't see buying NiMh anymore.
My other thought was start with a hull and parts and build my own. If I like the FFT I'll get it if not build or maybe even a Villian Ex
coolrunnings
09.02.2008, 03:03 AM
You will need to dip the ends of your packs in plastidip it's a it's a tool handle dip. Liquid rubber. Get a can of it at any hardware store for around 5 bucks. And yes water will ruin your lipo.
