glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.02.2008, 11:34 PM
I've never had a problem with the plastic gears either. Only if the motor slipped and mesh got real loose... then you will strip a gear. But even then, it's only $5.00
Running metal gears isn't so bad now that we have good pinions for $10-15
Not long ago, it's was very costly to run metal-metal. I've run plastic for several years now.... racing and bashing... works for me and it's quiet.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
MetalMan
MetalMan's Avatar
09.03.2008, 01:02 AM
My problem was the motor loosening up, on my Hyper 8 at least. In my Savage, with perfect mesh, I was MELTING Kyosho spurs. Like stripping, but there was never any stripping.
And for now at least, Mike is out of Kyosho spurs.
