I have found that disabling the punch control and using the throttle curve adjustment works well...gives you good control will still keeping the snappy performance
ive never tried that. so how do you have your throttle curve set? hows it look like
it starts in the lower left hand corner of the graph and goes laterally for a little than I start to cuve upwards slightly than its a straight line going in the direction of 2 O'clock
