gearing ...
Jason
gearing ... - 09.04.2008, 10:53 PM
Hi, guys possible I got a noticeable runtime down from 87t spur to 84t ?
09.04.2008, 10:56 PM
I doubt it.
brushlessboy16
brushlessboy16's Avatar
09.04.2008, 10:59 PM
would help if we had a setup, motor esc batts, maybe the vehicle its in...
could be undergeared- could be over geared- fixing either can ad runtime as the motor is more efficient
Jason
09.04.2008, 11:04 PM
vehicle : hpi e-firestorm 1/10 2wd stadium truck
motor : traxxas velineon 3500kv
esc : mamba max 1/10
gearing : 18t pinion / 84t spur
battery : 2s lipo 7.4v 5000mah
I want to try to get a good 20 to 25min of runtime from my setup ...
09.05.2008, 01:06 PM
Without knowing the diff and tranny ratios, I couldnt figure it out using the calcualtor- that said, a change of only 3 teeth on the spur wont make anything more than a tiny difference. What are your esc/batt/motor temps typically?
VintageMA
VintageMA's Avatar
09.05.2008, 03:53 PM
I remember reading an article on gearing somewhere a while back, and although not completely precise it eluded to basically a 4T change in the spur being = to a 1T change in the pinion. It's an approx good rule of thumb.
“Everyone has a right to be stupid; some people just abuse the privilege.”
