Darion
09.07.2008, 09:34 AM
Originally Posted by slimthelineman View Post
I have to say... those who puff 3 and go for 4 should check the fortune cookie that says your set up is wired like turd
wiring is fine, wiring doesnt work sometimes and not others. not a novice here by any means. if i can bring power from the gen. plant all the way to your home i pretty sure i can get my latest r/c to go.
Sorry to read all these reports of MMM's going up in smoke. I have one sitting in a box new that I haven't even bothered hooking up. I can't decide if I should run it or sell it. The problem is what do I go with the will run without issue? It seems that the esc's that are out just arn't up to the task at this point. BTW, I have a Savage SS, FLM conversion, Fiegio 8XL, 4s 25C 5000 pack. As mentioned above for 4s just run an MM but I want to go up to a 6s and I haven't found much on-hand inventory for the MM's sitting around.
Well, good kuck,
Darion
