starscream
RC-Monster TQ
starscream's Avatar
09.07.2008, 05:26 PM
I always run my packs in series as I've personally found more uses for smaller capacity high voltage packs than larger capacity lower voltage packs.
Then again, I've always run higher voltage than most.
Ha Ha
Electric Dave
09.07.2008, 06:43 PM
Did you mean parallel?
Small capacity and high voltage are what parallel is all about.
Large capacity and low voltage are where seres comes into play...
Just want to make sure I understand your post.
starscream
RC-Monster TQ
starscream's Avatar
09.08.2008, 03:07 AM
Sorry, I think I confused the topic
My suggestion would be to invest in packs that you will be able to utilize the most. If you run 4S in all your vehicles, then I would buy 4S packs so you have the option of running a single pack or in parrallel for more capacity.
I run 4S in my 1/10 scales and 8S in my 1/8th scales so I buy 4S packs and run 2 in series in my 1/8th scale.
I really don't see a major benefit of either configuration but I'd strongly suggest planning ahead so you can take the most advantage of the packs you buy.
Ha Ha
