azjc
09.08.2008, 03:49 AM
Originally Posted by lind5 View Post
ok that answers that cheers mate
but what if you have a 14.8 v 100 amp esc
and run a
14.8 v 25c 5000mah lipo
5amp x 25 = 125amps and thats without bursts of 30c
would this hurt the esc as the esc is only 100 amp
it depends on what the motor is asking for.....if the motor is asking for as lot of amps that is whats going to happen..this will happen especially with a lower turn motor
lind5
09.10.2008, 10:10 AM
when you say lower turn motor do you mean a lower kv rating
will a lower kv draw more power than a higher kv
azjc
09.10.2008, 11:10 AM
no its the opposite...lower turn = higher KV...and a higher turn motor will draw more amps, there is less wire in the winding so there is less resistance for the electricity to turn the rotor
