MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.08.2008, 08:53 AM
Do you know what gearing you are running? I put my eagle tree on my friends stampy with 5700 and he wasn't even pulling half the amp spikes you are. It wasn't the pack either as the voltage wasn't dropping much. His system runs pretty cool which is a good thing cause he runs it in tall grass but it is still plenty fast.
Edit: I am not having a go at your setup either. Just curious as to what your gearing is because he is obviously geared a lot lower then he could be.
lutach
lutach's Avatar
09.08.2008, 09:25 AM
They look good. How do they compare in size with other hard cased lipos?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.12.2008, 07:32 AM
I looked at the data on my eagle tree on the pc and I was wrong. The amp peaks are just as high. For some reason The power panel isn't displaying the proper peak max amps. I have sent eagle tree systems an e-mail about it but have yet to get a reply.
SPC Racing
09.12.2008, 09:33 AM
I'm interested in the response from Eagle Tree as my power panel also displays amp reads much lower than the data loaded to the PC.
