Thunderbruiser
Thunderbruiser's Avatar
10.26.2005, 06:17 PM
Virtual Test Stand Inputs
Open Circuit Voltage 1.25 Volts X 12 Cells = 15.00 Volts
Battery Resistance 0.0045 Ohms X 12 Cells = 0.0540 Ohms
Speed Controller Resistance = 0.010 Ohms
Motor Type 27/26/4
Motor, Unloaded 1172 RPM/Volt
Motor Resistance 0.096 Ohms
Motor no-load current 0.75 Amps Prop Type Thin Folding Prop
Propeller Constant 1.18
Diameter 6.0 Inches
Pitch 3.0 Inches
Gearbox Other Gearbox Ratio
Gear Box Ratio 1.00 :1
Virtual Test Stand Outputs
Prop RPM: 16355 RPM
Current: 6.5 Amps
Voltage into Motor: 14.6 Volts
Power Input: 95 Watts
Power Output: 81 Watts
Efficiency of Motor Only: 84.7%
Current at Max Motor Efficiency: 10.7 Amps
Pitch Speed: 46 mph
Thrust at Pitch Speed: 14 oz
here are the stats....and um really? why the truck is just too big or what?
are any of those stats good?
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
