Gustav
Gustav's Avatar
10.27.2005, 12:03 PM
Thanks Serum, i was a little conservative i guess with those speeds,i'd like a cool long running setup with excess power on tap.I'd like the ability to top 55mph occasionally.
I was edging towards the 10 turn,i think compared to what i would try with a 2240, maybe i should go with the slightly higher rpm and lower gearing to hit the same speed since it can spool up slightly quicker,i thought maybe the 10 turn might run a little cooler than the 11, as the same speed could be had with slightly lower gearing and so less load.
If it was a 2240 it would have the extra torque to shrug off this extra load,using the torque and lower rpms to accelerate,a little more so than with the 1950. This is all relative of course,i know this is still a big torquey motor,i'm still talking under 38000 rpm.
i'd like to know the likely real rpms under load with these cells(kokam 3200),as i'd like to keep it well below the 42000 limit.would there be much voltage drop under load?,i'd like to keep the real loaded rpm to around 35000.
