brushlessboy16
brushlessboy16's Avatar
09.12.2008, 06:32 AM
very nice conversion, neat and clean-now all you need is more voltage
Bronco
09.12.2008, 06:56 AM
Wow, thats cool.
Could you explain how you managed to fit the outdrive's of both drive shafts to the motor.
For the motor shaft I understand, but how did you do the rear.
And what is that brace you are using. Can't really see in the pics.
How are its handling capacities now the center diff has gone ?
BL-Power
BL-Power's Avatar
09.12.2008, 07:07 AM
I've moved the motor shaft through the motor so that 2/3 of the shaft looks out at the front and 1/3 of the shaft looks out at the rear. I have replaced the two braces by the long rod from the front to the rear.
It's handling very nice, i don't feel a great difference without the center diff.
I'd like some more voltage for speed runs but i couldn't find 5s or 6s batteries with a small capacity like 1800mah or something like that.
 Send a message via ICQ to BL-Power
lutach
lutach's Avatar
09.12.2008, 07:35 AM
Very nice conversion.
brushlessboy16
09.12.2008, 07:37 AM
Originally Posted by Bronco View Post
Wow, thats cool.
some outrunnerscome with the shaft out both sides-some you have to slide it through.
