jhautz
jhautz's Avatar
09.17.2008, 11:25 AM
http://www.teamxray.com/teamxray/sho...p?file_id=4461
Here is an awesome setup guide for buggy and truggy. Very useful when trying to solve a handling problem.
Its published by Xray but the principles apply to any buggy of truggy.
And I 100% agree with backfire. Without the right tires, you are just chasing your tail. Tires are the first and most importenat piece of any track setup.
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
09.17.2008, 11:36 AM
To answer the dif oils questions:
EFFECTS OF DIFFERENTIAL OIL REPLACEMENTFront
Thinner
• Increases steering into corners (off-power)
• If oil is too thin the steering may become inconsistent, especially it can lose forward traction (and steering) during acceleration out of corners
Thicker
• Increases stability into corners during braking
• Increases steering on-power at corner exit
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too much power and sometime “cook” the oil in the center differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high power engine is used - you might need to be smooth on the throttle
Rear
Thinner
• Increases cornering traction
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
to make it...
or break it...
Silent...But Deadly
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.18.2008, 12:46 AM
Sweet, thanks for the link
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
