Sammus
Sammus's Avatar
09.19.2008, 06:28 AM
105 exactly doesnt matter, thats just to make it fit, and you want to sure its bent in one plane and to the same angle.
if the sway bars are the right size and are set up properly they offer a huge improvement in handling. Basically they reduce bodyroll significantly, ie make the truck sit flatter, reduce traction roll, and help even out the load on each side (ie won't pan the inside wheel as easily)
Sway bars also drastically alter the over/understeer tendancy of your truck so it will require some messing around to set properly.
