Test Ok
TRUGGYMAN
Test Ok - 09.20.2008, 06:19 PM
Tomorrow i race with the MGM E serie TMM 28025-3 Car on a
truggy Eight T with NEU 1515 1.5 DF.
I went today for practice and it runs perfect. Even when grip
is low, wheelie on throtle-up is no problem.
I set the cut-off at 3.2v. After 2 hours rest, my pack gives
3.38v and i put back 5100 Mah on a 6000 pack ( Poly Rc ).
I run 17 min hard, up to the max slow down of the ESC.
The car was fine on this track with a standard setup.
By the way, it's the 1st time the T runs.
BUT, tomorrow is another day:
3 x 5 min qual + 3 x 15 min race.
My STRR truggy will race with an old MGM EXPERT+ 28025-3 and a
NEU 1515 2D. Smoother on gaz but not so thursty on packs.
I can run longer with a lower Kv.
Brushless: 2 truggies + 3 buggies
against 45 smoky....
Wait & seee
Running Perfect
TRUGGYMAN
Running Perfect - 09.22.2008, 05:19 PM
The 2 truggies made the all races without any troubles.
STRR + old MGM made qualifications 5:3:1
The 15 min finals were with starting position B4
Ended 4 + 1 ( 3rd canceled due to the dark )
eIGHT T with MGM E serie made qualifications 5:2:4
Starting final A9 and made 5+4.
No doubt that the MGM are strong. The track was very slippy
on 1 side and a lot of grip on both side. It's always U turns
with brake max + nearly full throttle with wheeling sometimes.
The packs were just to hold the 15 min but this track needs energy.
By the way, all 3 other brushless ( not Neu & not MGM ) didn't end
a qual or final without thermalling.......
Total with MGM: 8 races + many practice = +/- 12 hours run.
No fan breakage and no troubles:
DO YOU KNOW WHAT? I'AM HAPPY.
